Raspberry Pi Drone Kit: The Ultimate Prototyping Kit To Bring Any Idea To Life, 10x Faster Than Normal By Using What Comes With The Kit... With Zero Prior Knowledge Required. See The Four Surprise Bonuses Your Kit Comes With At The Bottom.
Our kit is more than a piece of hardware, it's also a conduit to expand your skills into domains like 4G control, light shows, drone delivery, computer vision aided flight, and a ton more.
See Some of What Your Raspberry Pi Drone Is Capable Of...
Autonomous Python Missions
Autonomous Drone Delivery
Computer Vision Influenced Flight
Drone Light Show
Inch Level Accurate GPS
4G Drone Control
What's Included In Your Drone Kit...
  • Raspberry Pi 4B
  • Pixhawk Flight Controller
  • Drone Frame
  • Four Brushless Motors
  • Four ESCs
  • RC Transmitter and Receiver
  • 3D Printed Vibration Dampening Plate
  • SD Card and SD Card Reader
  • Mounting materials
  • Camera
  • Lipo Battery
  • Lipo Battery Charger
  • Lipo Battery Fire-proof case
  • Eight Propellers
  • GPS and Compass Module
  • GPS mount
  • All connectors you’ll need
  • Telemetry Modules
  • Screws, screwdrivers, hex keys
  • A ton more
We designed this kit with a dual purpose: to help you learn drone engineering from the ground up, and then push the boundaries once you’ve mastered the skills. Built on ArduPilot, Raspberry Pi, and Python-controlled autonomy, this kit gives you the power to build whatever the heck you want — once you’ve got the fundamentals down.
No need to go through the painful process of having to find your own parts! Just Put the Jacket On!
Every single item required to build this drone is included with your drone kit. All the parts are compatible and have been quality controlled, allowing you to save tons of time and get to the fun stuff much faster!
Additionally, we buy in bulk. So it costs us way less to get the parts compared to someone building a single drone. Essentially, the price of this kit is the same, or a little cheaper, than if you were to find all the 40+ parts on your own.
Your Kit Comes With A 5+ Hour Building Course
You’re not just getting hardware with this drone. It also comes with our 5+ hour “How To Build A Raspberry Pi Drone” course that you will own for life. This drone is not like ordering parts from Amazon and having to figure out what to do with the parts on your own.
  • Learn how to build the drone
  • How to calibrate it and get flight ready
  • Program autonomous missions
  • How to stream video from the drone to your computer
  • Custom Drone Dojo Raspberry Pi image with all dependencies already resolved and example python scripts pre-loaded
Your Next Projects, Once You’ve Built the PiHawk
This drone is at the core of our Drone Dojo engineering platform. All of the courses we offer use this exact drone. So if you have interest in expanding your drone engineering skills into drone delivery, 4G control for limitless range, light shows, RTK GPS for inch level precision, precision landing using computer vision, optical flow for GPS denied flight, autonomous python control, etc, you’ll be using the perfect drone to follow along with what we teach.
Other Drones Like This Cost Thousands of Dollars...
ModalAI - $3,000
HiTec SUI - $13,000
Why So Expensive? Because They Are Targeting Businesses
We are targeting tech hackers like yourself who want access to an affordable yet highly capable programmable drone, so we can charge WAY less than our competitors…
Join Thousands of Builders Who Reserved Their PiHawk Drone Kit for...
$1,000
$899!
SUPPLY IS LIMITED!
This Drone Kit May Be The Cheapest Option To Truly Learn Drone Engineering With, But It's Using the Exact Same Open Source Tools That Multi-Million Dollar Companies Are Using
  • ArduPilot Flight Control Code (Used by Matternet, a Drone Delivery Company that has received $16 million in funding)
  • ArduPilot supports a HUGE array of sensors.. simply plug them in like lego blocks as needed (Matternet used a $300 dollar precision landing sensor called IR-Lock to land within 15 cm of a target consistently)
  • Pixhawk Flight Controller (Open source hardware that is used on a ton of commercial drones)
  • Autonomous Control with Python-Dronekit (a package to write python scripts with high level drone functions to control the drone’s movement.. NO RC required!)
You're Not Only Getting This Raspberry Pi Drone Kit...
Order Today and Receive Three Bonuses to Go Along With Your Purchase!
BONUS 1: Lifetime Access To The "How To Build A Raspberry Pi Drone" Course
This course shows you step by step how to put together your PiHawk drone. In addition to that, it walks you through more advanced topics like no-code autonomous flight, python controlled flight using the raspberry pi, and even access our pre-made raspberry pi images that has example python control scripts already pre-loaded, and all the dependencies already resolved. It even comes with a custom script to easily stream video from your drone to your computer. In total, it’s a 5+ hour course. We used to sell this course as a standalone product at $99 and we’ve attached proof of that below. Now, you will be getting it for free with your drone.
$99 Value
BONUS 2: Direct Access to Our Drone Dojo Community Forum Where Experts Will Answer Your Questions
While the courses are a huge aid in your knowledge onboarding, we know that you may still have questions that are unique to your situation.
Or perhaps, you’d like some guidance on a pet project you’re working on after you’ve completed our Blue Belt curriculum.
For this reason, we created the Drone Dojo Forum, which is exclusive to Blue Belt members. Here, you can ask any technical question that is hanging you up, and an expert will be in touch with you.
Experts can save you months.. or even years. How valuable is your time?
$1,000 Value
BONUS 3: Smoke Stopper to Detect and Prevent Shorts so You Don't Fry Your Drone.
One of the biggest problems new drone builders encounter is shorting out their drone. They have no idea there is an issue, they plug in the battery, and the lovely plume of electronic smoke shoots into the air.
And just like that, their electronics are fried. They get frustrated, and never complete their drone build.
This is easily preventable with what I am including in this offer- a smoke stopper!
You simply plug this in between your drone and your battery when first powering up. If there is a short, the smoke stopper won’t allow the surge of electricity to hit the electronics, and you can get to diagnosing the issue. The hardware is spared!
$27 Value
BONUS 4: Custom Drone Dojo Raspberry Pi Image
We’re also offering with this rover our custom Drone Dojo Raspberry Pi image you can flash to your Raspberry Pi. What’s special about it? Firstly, you get to avoid what is called “dependency hell”, where all of the software and programs are already pre-installed on this image. Secondly, it comes pre-loaded with a ton of example python scripts you can use to control your drone. Thirdly, we made a custom command you can use to stream video from your drone to your computer. This is easily saving you months of time alone if you’ve never done any of this before.
$300 Value
Here is EVERYTHING You Get When You Order Your Own Raspberry Pi Drone Today!
  • Raspberry Pi and Pixhawk Drone Kit                                    ($1,000)
  • How To Build A Raspberry Pi Drone Course                              ($99)
  • Access to Drone Dojo Forum                                                ($1,000)
  • Smoke Stopper to Prevent Shorts                                              ($27)
  • Custom Raspberry Pi Image                                                     ($300)
Total Value: $2,426.00
If You Order Today, Get All This For Just...
$899
How long does the drone fly?
Without a payload, 25 minutes.
What is the payload capacity?
About 800g, perfect for mounting your own custom gear to the PiHawk drone.
Do you ship internationally?
Yes, with free shipping included.
Are you in stock?
Yes.
What if I want a refund?
Not a problem! We offer a 30 day money back guarantee. Just ship the drone back to us and we'll process the refund. So with that in mind, what do you really have to lose?
