Raspberry Pi Rover Kit: The Solution To Bringing Your Robotics Project To Life.
Attention all tech nerds! Learn how to build, program and run an advanced autonomous rover capable of computer vision, artificial intelligence and machine learning.
See Some of What Your Raspberry Pi Rover Is Capable Of...
Computer Vision Guided
Voice Controlled Rover
Autonomous Spray Painting
What's Included In Your Rover Kit...
  • Jetson Nano or Raspberry Pi
  • Pixhawk Flight Controller
  • 1/10th Crawler Chassis
  • Brushed Motor
  • Brushed Motor ESC
  • RC Transmitter and Receiver
  • 3D Printed Mount
  • Webcam for OpenCV Scripting
  • Mounting materials
  • Lipo Battery
  • Lipo Battery Charger
  • Lipo Battery Fire-proof case
  • WiFi Telemetry Module
  • GPS and Compass Module
  • GPS mount
  • Steering Servo and small servo for delivery
  • Screws, screwdrivers, hex keys
  • A ton more!
We designed this kit with a dual purpose: to help you learn robotics engineering from the ground up, and then push the boundaries once you’ve mastered the skills. Built on ArduPilot, Raspberry Pi, and Python-controlled autonomy, this kit gives you the power to build whatever the heck you want — once you’ve got the fundamentals down.
No need to go through the painful process of having to find your own parts!
Every single item required to build this rover is included with your kit. All the parts are compatible and have been quality controlled, allowing you to save tons of time and get to the fun stuff much faster!
Additionally, we buy in bulk. So it costs us way less to get the parts compared to someone building a single rover. Essentially, the price of this kit is the same, or a little cheaper, than if you were to find all the 40+ parts on your own.
Your Kit Comes With A 5+ Hour Building Course
You’re not just getting hardware with this rover. It also comes with our 5+ hour “How To Build A Smart Rover” course that you will own for life. This rover is not like ordering parts from Amazon and having to figure out what to do with the parts on your own.
  • Learn how to build the rover
  • How to calibrate it and get it driving ready
  • Program autonomous missions
  • How to stream video from your rover to your computer
  • Custom Drone Dojo Raspberry Pi image with all dependencies already resolved and example python scripts pre-loaded
Your Next Projects, Once You’ve Built the Rover
This rover is at the core of our Drone Dojo engineering platform. All of the courses we offer use this exact rover. So if you have interest in expanding your robotics engineering skills into rover delivery, 4G control for limitless range, RTK GPS for inch level precision, precision parking computer vision, autonomous python control, etc, you’ll be using the perfect rover to follow along with what we teach.
Other Rovers Like This Cost Thousands of Dollars...
AION UGV - $5,000
TT Robotics - Not even listed (to not scare people away from the price)
Why So Expensive? Because They Are Targeting Businesses
We are targeting tech hackers like yourself who want access to an affordable yet highly capable programmable rover, so we can charge WAY less than our competitors…
Reserve your Smart Rover Kit Today for...
$1,000
$899!
SUPPLY IS LIMITED!
This Rover Kit May Be The Cheapest Option To Truly Learn Robotics Engineering With, But It's Using the Exact Same Open Source Tools That Industry Leading Rover Developers Use
  • ArduPilot Control Code (Used by many autonomous lawn mowing companies. Below is a video displaying this.)
  • ArduPilot supports a HUGE array of sensors.. simply plug them in like lego blocks as needed (Matternet used a $300 dollar precision landing sensor called IR-Lock to land within 15 cm of a target consistently)
  • Pixhawk Flight Controller (Open source hardware that is used on a ton of commercial rovers)
  • Autonomous Control with Python-Dronekit (a package to write python scripts with high level rover functions to control the rover’s movement.. NO RC required!
You're Not Only Getting Smart Rover Kit...
…Which is insanely valuable all on your own. Good luck trying to find what parts you need to build a rover when you don’t even know what parts you need, let alone if the various parts are compatible…
Order Today and Receive Three Bonuses to Go Along With Your Purchase!
BONUS 1: Lifetime Access To The "How To Build A Smart Rover" Course
This course shows you step by step how to put your rover together. In addition to that, it walks you through more advanced topics like no-code autonomous missions, python controlled missions using the raspberry pi, and a bunch of other topics. In total, it’s a 5+ hour course. We used to sell this course as a standalone product at $99. Now, you will be getting it for free with your drone.
$99 Value
BONUS 2: Custom Drone Dojo Raspberry Pi Image
We’re also offering with this rover our custom Drone Dojo Raspberry Pi image you can flash to your Raspberry Pi. What’s special about it? Firstly, you get to avoid what is called “dependency hell”, where all of the software and programs are already pre-installed on this image. Secondly, it comes pre-loaded with a ton of example python scripts you can use to control your rover. Thirdly, we made a custom command you can use to stream video from your rover to your computer. This is easily saving you months of time alone if you’ve never done any of this before.
$300 Value
BONUS 3: Pre-configured ArduPilot Parameters and PID Values
So we already established we are pre-flashing the firmware for your pixhawk and Raspberry Pi. If you’re not aware, there are hundreds of parameters that change the functionality of your Rover. These are configurable in a ground control station like MissionPlanner, but how the heck do you know which parameters you need to change/alter?
We have vetted 20+ parameters that we tested on our rover, and you will be able to use our parameter file and simply upload it to your pixhawk. Don’t worry, we’ll show you how to do this in the course. This includes the PID values that produces smooth driving while your rover is in autonomous drive modes. Without these PIDs, you’d have to manually tune these on your own (which can be a painful process.. it took me an entire day to accomplish this the first time)
$200 Value
BONUS 4: Direct Access to Our Drone Dojo Community Forum Where Experts Will Answer Your Questions
While the courses are a huge aid in your knowledge onboarding, we know that you may still have questions that are unique to your situation.
Or perhaps, you’d like some guidance on a pet project you’re working on after you’ve completed our Blue Belt curriculum.
For this reason, we created the Drone Dojo Forum, which is exclusive to Blue Belt members. Here, you can ask any technical question that is hanging you up, and an expert will be in touch with you.
Experts can save you months.. or even years. How valuable is your time?
$1,000 Value
BONUS 5: Pre-soldered Power Module With UBEC Power Supply
Your Raspberry Pi needs a 5V 3A power supply powered through USB-C in order to operate. The standard power module that takes power from the LiPo battery and powers the PixHawk doesn’t have this UBEC for the Pi, so you have to manually solder a UBEC onto the power module, then solder on USB-C cable to the UBEC.
You can see, this can be a pain.
Rover kit purchasers will get this part PRE-SOLDERED and customized for your Pi build! So for you, it is just another plug and play part. For others…. a hair pulling out event.
$47 Value
Here is EVERYTHING You Get When You Order Your Own Smart Rover Kit Today!
    • Smart Rover Kit        ($1,000)
    • How To Build A Smart Rover Course                                      ($200)
    • Access to Dojo Dojo Forum                                                    ($300)
    • Pre-soldered Parts        ($47)
    • Pre-configured Parameters and PIDs                                         ($200)
    • Custom Raspberry Pi Image                                                       ($300)
Total Value: $2,545.00
If You Order Today, Get All This For Just...
$899
How long does the battery last?
Without a payload, 45 minutes.
Do you ship internationally?
Yes, with free shipping included.
Are you in stock?
Yes.
What if I want a refund?
Not a problem! We offer a 30 day money back guarantee. Just ship the rover back to us and we'll process the refund. So with that in mind, what do you really have to lose?
