PiCam Back
Back plate of the PiCam mount. It snaps into the PiCam front for a press fit. Works with PiHawk and Micro PiHawk Kits.
PiCam Front
Front plate of the PiCam mount. It snaps into the PiCam back for a press fit. Works with PiHawk and Micro PiHawk Kits.
Pixhawk Plate
Plate that the pixhawk sits on for PiHawk drone kits. It mounts to the vibration dampener top plate of PiHawk drones.
Micro FC Mount
Micro PiHawk mount for the F405-HDTE flight controller. Works for all 30x30mm flight controllers.
Rover Pi Mount
Mounts to the chassis of rover kits. Mounting holes align with the raspberry pi. The bottom of this plate mounting tapes to the chassis.
Extra Rover Mount
Extra mount platform for PiHawk rover kits. Great for things like lidar, extra sensors, speaker, etc.
Vibration Plate Bot
Vibration plate that connects to vibration plate top. Reduces vibes felt by the pixhawk on PiHawk drone kits.
Vibration Plate Top
Vibration top plate that mounts to the bottom plate with vibration dampeners. Then has mount points for the Raspberry Pi on Pihawks.
NeoPixel Mount
Middle mounts are for 8xNeopixel sticks with M2x4 screws. The outer mounts secure it to the bottom frame plate of Pihawk drone kits.
NeoPixel Diffuser
Pairs with Neopixel mount. Best when printed with see through filament. Helps to create a uniform ‘light bulb’ light from the individual Neopixel LEDs.
ArduSimple Mount
ArduSimple Mount for the RTK2B board. The outer mount points mount onto the modified pixhawk plate, and the inner mounts to the ArduSimple board.
Outer Drone Leg Lock
Drone leg extension for PiHawk drone kit. This pairs with the drone leg STL, and the two zip tie together.
Outer Drone Leg
Pairs with the drone leg lock. This drone leg provides more ground clearance for PiHawk drone kits.
Modded Pixhawk Plate
This modded pixhawk plate allows for stacking of electronics on top of the pixhawk. The inner mount points screw into the top plate of the drone or rover, and the outer mount points are for spacers. An example of what would sit on top of this is the ArduSimple mount.
